Suppress GDAL raster tags
5261
7
04-07-2015 03:45 AM
BenLeslie1
I used Arc to slice a large raster into smaller tiles for use in a separate in-house programme.
Unfortunately when loading the rasters into our programme we get a couple of errors/warnings.  The cause of these warnings has been identified as a couple of GDAL tags (the tags relate to nodata value and general metadata).  Is there some way to suppress the generation of these GDAL tags when I process the imagery in Arc / arcpy?
Sorry if the description is very basic - I am just the GIS tech, not a software developer.
Luke_Pinner
MVP Regular Contributor
Assuming they are tiffs and you have a working GDAL install, you can use the PROFILE creation option to specify GEOTIFF instead of the default GDALGeoTIFF:
gdal_translate -co PROFILE=GeoTIFF in.tif out.tif
Luke_Pinner
DanPatterson_Retired
Luke just a head up.  your code post for some reason got Moderator tagged.  In the future try enclosing it in quotes rather than puttting it in a code block.  If it gets flagged again, I will pass it up the line my guess as to what did it is as good as yours.  I have notified Timothy Hales​ in case he knows
Luke_Pinner
Thanks Dan. I was wondering why I got moderated. Oh well, at least I now know who moderates the moderators
You must have gotten thrown out of the moderator queue through through your spammy actions
BenLeslie1
Hi Luke - this sounds like what I need to do (you're right to assume they're tiffs, sorry for leaving off vital info).
I need to ask some follow-up questions.....I'm new to gdal code and have not really used much code beyond arcpy.
How do I run this code, is it python?
How do I know if I have a working GDAL install? - I have lots of folders on my computer called GDAL in amoungst program files for FME, Arc and QGIS - the gdal website goes over my head somewhat.
Thanks
Ben
Luke_Pinner
Ben, gdal_translate.exe is a commandline program, you run it from a command prompt. I was assuming you had a working gdal install to generate those files in the first place. How did you create/get them?
You could also try the ArcGIS Copy Raster tool to see if that strips the tags.
BenLeslie1
Thanks - I'll look into gdal_translate.exe.
The tags were apparently created by Arc's Clip tool.
