Split and Rearrange Text With Arcade?
12083
05-01-2019 09:00 AM
deleted-user-1_r2dgYuILKY
I have fields with names in the format last, first, middle initial. I would like to display them as first, ME, last. Is this possible in Arcade using the Split function?
Tags (1)
KenBuja
MVP Esteemed Contributor
How is your data formatted? If it's in a field as "Smith, John A" then you can use
var arrName = split($feature.name, ",")
return arrName[1] + " " + arrName[0]‍‍‍‍‍‍‍‍
This returns "John A Smith"
KenBuja
There's no comma just spaces, but this works. Thanks!
KenBuja
Glad to help. Don't forget to click the "Mark Correct" button.
SarahHartholt
I have created a Cell_ID field to store grid index values in a road feature class. For example, if Main St. falls within grid cells B1, B2, C2 & C3, my Cell_ID field is populated with "C3,B2,C2,B1". Is there any way for me to reorder the values alphabetically and then numerically as B1, B2, C2 & C3?
Solved my problem below:
var arrName = split($feature.Cell_ID, ",")
return concatenate(sort(arrName))
