select features within a distance
8355
9
05-04-2015 04:33 AM
sundussabbah
Hello,
I have a map with feature layer and I want to press a button and it's event display only the features around the current location within specific radius
I want to :
define the current location
display features that exist around the current location with a specific radius
please help me, how could I do this??
thanks alot
TomSellsted
Greetings Sundus,
Here is a sample script from ESRI's page that queries using geometry.  In this sample, it uses and extent, but you could easily reference the new geometry engine to create a buffer too.
https://developers.arcgis.com/javascript/jssamples/query_deferred_list.html
The specific bit of code that queries by geometry is:
        app.map.on("click", executeQueries);
        function executeQueries(e) {
          var parcels, buildings, promises,
            qGeom, point, pxWidth, padding;
          // create an extent from the mapPoint that was clicked
          // this is used to return features within 3 pixels of the click point
          point = e.mapPoint;
          pxWidth = app.map.extent.getWidth() / app.map.width;
          padding = 3 * pxWidth;
          qGeom = new Extent({
            "xmin": point.x - padding,
            "ymin": point.y - padding,
            "xmax": point.x + padding,
            "ymax": point.y + padding,
            "spatialReference": point.spatialReference
          // use the extent for the query geometry
          app.qParcels.geometry = app.qBuildings.geometry = qGeom;
          parcels = app.qtParcels.execute(app.qParcels);
          buildings = app.qtBuildings.execute(app.qBuildings);
          console.log("deferreds: ", parcels, buildings);
          promises = all([parcels, buildings]);
          promises.then(handleQueryResults);
          console.log("created d list");
Here is a reference to the buffer geometry engine code.
esri/geometry/geometryEngine | API Reference | ArcGIS API for JavaScript
Regards,
Tom
sundussabbah
it does not work or I did'nt understant it well
I have this code:
  var circleSymb = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NULL,
new SimpleLineSymbol(
  SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
new Color([105, 105, 105]),2), new Color([255, 255, 0, 0.25]));
var circle = new Circle({
  center: [long,lat], // coords for the current location
  geodesic:
true,
  radius: radius, // radius for the area whic I want to display features
  radiusUnit:
9036 // unit "kilometer"
and this code, it does'nt work, and  I did'nt know how to apply circle object with it:
  var  geometries = graphicsUtils.getGeometries(lyrFeature.graphics);
var bufferedGeometries = geometryEngine.geodesicBuffer(geometries, radius, 9036, true);
  array.forEach(bufferedGeometries,
function(geometry){
  map.graphics.add(
new Graphic(geometry,circleSymb));
TomSellsted
Sundus,
Of course you can just use a circle and no buffer needed to query as well.  It would go something like this:
          var parcels, qGeom, point;
          point = e.mapPoint;
          var qGeom = new Circle(point,{
            "radius": 100,
            "spatialReference":point.spatialReference
          // use the circle for the query geometry
          qParcels.geometry = qGeom;
          parcels = qtParcels.execute(qParcels, handleQueryResults);
I am using a circle for the query geometry instead of an extent.  You can change the radius to whatever you would appropriate for your query.
Regards,
Tom
TomSellsted
Sundus,
I put together a quick jsfiddle for you to be able to see the complete javascript.  You can view it at:
Edit fiddle - JSFiddle
Regards,
Tom
sundussabbah
I wrote the code like this
query = new Query();
  query.where = condition;
  query.returnGeometry =
true
if(search != false){
var qGeom = new Circle({
  center: [
longitude,latitude],
  geodesic:
true,
  radius: radius,
  radiusUnit:
9036
  mapMain.graphics.clear();
  mapMain.infoWindow.hide();
var graphic = new Graphic(circle, circleSymb);
  mapMain.graphics.add(graphic);
  query.geometry = qGeom;
  query.outFields = [
  query.orderByFields = [order];
  queryTask.execute(query, showResults);
but the result is nothing.!!!
TomSellsted
Sundus,
It is hard to tell with the code fragment you posted, what is going on.  I suspect that the latitude and longitude may not be passed to the function so there is no geometry to add to the query.  Is a circle being drawn on the map in the place you are expecting?
From your previous post, you didn't want to expose your service URLs, so if you could post the code without them, I might have a better chance of seeing what is going on.
Regards,
Tom
sundussabbah
Hello,
it is the same query you helped me with. in the previous post, but now now I want to add a button (search) if it is pressed the query display only the features that exist around a point with specific readius ( the point is the current location of user) long & lat are for this point
this is the previous code you wrote :
<!DOCTYPE html>
<html>
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Query Musanda Project Details</title>
    <script src="http://js.arcgis.com/3.13/"></script>
    <script>
        require([
            "dojo/dom", "dojo/on",
            "esri/tasks/query", "esri/tasks/QueryTask", "dojo/domReady!"
        ], function(dom, on, Query, QueryTask) {
            on(dom.byId("execute"), "click", execute);
            function execute() {
                queryTask = new QueryTask("URL to your Map Service");
                //build query filter
                query.where = "ESRI_OID > 0";
                query.returnGeometry = false;
                query.outFields = ["*"];
                query.spatialRelationship = Query.SPATIAL_REL_INTERSECTS;
            function showResults(results) {
                var resultItems = [];
                var resultCount = results.features.length;
                for (var i = 0; i < resultCount; i++) {
                    var featureAttributes = results.features.attributes;
                    for (var attr in featureAttributes) {
                        resultItems.push("<b>" + attr + ":</b>  " + featureAttributes[attr] + "<br>");
                    resultItems.push("<br>");
                dom.byId("info").innerHTML = resultItems.join("");
    </script>
</head>
<body>
    Projects:
    <input id="execute" type="button" value="Get Details">
    <br />
    <br />
    <div id="info" style="padding:5px; margin:5px; background-color:#eee;">
    </div>
</body>
</html>
and to do what I want (display within a radius) I wrote this code:
  query.returnGeometry = true;
 if(search != fals){   // to check if button is pressede
  center: [longitude,latitude],  // longitude & latitude of current location ( obtained in another function)
  geodesic: true,
  radius: radius,             // radius to search within ( it is global variable initialized early)
  radiusUnit: 9036
it is not necessary to draw the circle , but when the query did'nt work , I tried to draw it to see what happens,
I hope my point is clear now, and thank you very much for keeping answer me
curtvprice
TomSellsted
Sundus,
This is the same code block that you provided me previously.  Without the rest of your code, it is difficult for me to see where things may be going wrong for you.
A couple of suggestions.  The circle may not have the right spatial reference and may not be selecting points as it is improperly located.  This is why I suggest drawing the circle, Then you can see the circle and the points that are falling within it.  If you are in debug mode, you can see what the values are for the lat/lon coordinates.  This way, you will know if they have the proper values to place a circle as expected.
Regards,
Tom
