maps for office
6928
7
11-11-2015 11:02 AM
SvivaManager
Hi, I've been trying to create a layer out of an excel table with many different columns which two of them are coordinates with a different spatial reference then the default one. i'm using 2039. When the data is being added to the map, it shows up perfectly for a second and then disappears.. the map says all the point were marked as errors! any idea why is that??
KyleBalke__GISP
Sviva,
Have you selected the spatial reference in the Add data from my spreadsheet dialog to match your data?
JakeSkinner
Esri Esteemed Contributor
Hi Sviva,
Would you be able to upload a sample of your excel spreadsheet?
SvivaManager
Hi Jake, thanks for the quick reply.
I was just about to reply to you that I've tested it on a smaller sheet and it worked out fine and while going back to take a screen shot all points disappeared again and marked as errors! so weird.
I attached the excel and screenshot of the error
I suspect it might work at your side because of basemaps with a different spatial reference - in my case I can choose only my own basemaps which all have a unique spatial reference.. not web mercator that is
JakeSkinner
What is the coordinate system of your basemaps?
SvivaManager
My basemap's spatial reference is 2039... What Kyle wrote fixed my problem I didn't notice that option. thanks
KyleBalke__GISP
Sviva,
SvivaManager
Thank you Kyle, I didn't even notice that option exists.. It solved my problem.
A bit irrelevant but any idea if all types of named users can have this plug-in for excel to use?
For ArcGIS Pro for example you need to be a named user with a desktop license.
KyleBalke__GISP
Esri Maps for Office does require a named user on an ArcGIS Online for Organizations subscription.  No desktop license required.
See the System Requirements section
Esri Maps for Office | ArcGIS
