Joins (ShapeFIle X Database)
11050
11
02-23-2015 06:25 AM
klebervaz
Hi Gys,
I have a ShapeFile whith all information displayed on the map. I connected a database (Oracle) with non-spatial data to make some joints, I realized that in option (Join and Relates) can only make only a join shapefile with database.
How could these joins shapefile with data bank unreferenced?
That would be the best solution?
Attached
klebervaz
Thanks for the support!
This I already managed to do, The problem is when I try to join with other table to present different situations in the map, ArcMap stops working
I wonder if there is another way to fazzer this?
klebervaz
I solved the problem
