Invalid Argument - ArcGIS SDK for iOS Error
1640
07-17-2017 04:01 AM
AbineshSolairaj
The following is the code, which I use to query the geodatabase.
                        if featureTable.hasGeometry {
                            let query = AGSQueryParameters()
                            let feature = featureTable.tableName
                            query.whereClause = "1=1"
                            featureTable.queryFeatures(with: query, completion: {(results: AGSFeatureQueryResult?, error: Error?) in
                                var result = results?.featureEnumerator().allObjects
                                for feature in result!{
                                    graphic = self.createGraphicForFeature(feature: feature)
                                    let featureLayer = AGSFeatureLayer(featureTable: featureTable)
                                    self.map?.operationalLayers.add(featureLayer)
                                    completion(nil, graphic)
I get the following error whenever I try to query the features and also it takes a lot of time to render each of the features.
2017-07-17 15:02:29.209 AppName[10703:350316] ArcGIS Runtime Error Ocurred. Set a breakpoint on C++ exceptions to see the original callstack and context for this error:  Error Domain=com.esri.arcgis.runtime.error Code=2 "Invalid argument" UserInfo={Additional Message=Null value., NSLocalizedFailureReason=Null value., NSLocalizedDescription=Invalid argument}
Appreciate your help.
KamruddinShah
Hey Abinesh, I was also facing the same issue. Please let me know if you get any update from ESRI or someone else.
Thanks in advance.
