How to select a Portal Network Data Source in modelbuilder for further analysis in ArcGIS Pro 2.0?
1269
07-06-2017 06:06 AM
niklasGregersen
Hello
I have setup the model below to create a route. I then want to create a buffer around my route but I cannot select the route as input. The data type of the route layer is a "Portal Network Data Source". Is there any tools I can use to make the route layer selectable for further analysis in my model?
Niklas Gregersen
JakeSkinner
Esri Esteemed Contributor
Hi Niklas,
Try converting the route to a feature layer using the Make Feature Layer tool.
