how to make clusters from small polygons with constraint of boundary touching?
6024
03-11-2015 12:06 PM
waqarahmad
I want to make some clusters from a bunch of small polygons with the constraint that each basic unit (polygon) in the resultant cluster must share a portion of its boundary with at least one other basic unit (polygon) in the same cluster. This is becuase of the reason that i want the resultant clusters contagious.
DarrenWiens2
You can pull out polygons intersecting at least one other polygon using the following script:
>>> polys = []
... outPolys = []
... with arcpy.da.SearchCursor("YOUR_POLYGON_LAYER_HERE","SHAPE@") as cursor:
...    for row in cursor:
...        polys.append(row[0])
... for i in range(len(polys)):
...    overlap = 0
...    for j in range(len(polys)):
...        if polys.distanceTo(polys) == 0:
...            overlap = overlap + 1
...    if overlap > 1:
...        outPolys.append(polys)
... arcpy.CopyFeatures_management(outPolys,'in_memory\polys')
DarrenWiens2
How do you want to deal with overlapping polygons (e.g. area of smaller polygon may fully overlap, but boundary may be far inside the larger polygon)?
waqarahmad
i have only polygons which touching EACH OTHER'S boundry
DarrenWiens2
>>> polys = []
... outPolys = []
...    overlap = 0
...    if overlap > 1:
yosukekimura
I haven't tested, but
     p.disjoint(q)
intead of
     p.distanceTo(q)==0
may runs faster particularly when there are a bunch of polygon.
your method is O(n^2) so may have trouble with large number of polygons...
yosukekimura
Darren's method should work, and this is an alternative.
# make table of pair of zero distance
arcpy.GenerateNearTable_analysis(fcOrig, fcOrig, tblNear, "0",
    "NO_LOCATION", "NO_ANGLE", "CLOSEST", "0")
if int(arcpy.GetCount_management(tblNear).getOutput(0)) > 0:
  # grab ids that showed up in the table
  ids = set([ _[0] for _ in  arcpy.da.SearchCursor(tblNear,('IN_FID'))])
  # grab shape
  oid = arcpy.Describe(fcOrig).OIDFieldName
  outpoly = [_[0] for _ in arcpy.da.SearchCursor(fcOrig, [ 'SHAPE@, oid])
      if _[1] in ids ]
  # save
  arcpy.CopyFeatures_management(outpoly, fcTouching)
