How to get Google maps as a background map in ArcMap ?
8308
02-18-2015 01:01 AM
tanerkoka1
JayantaPoddar
Hi Taner,
You could use open web maps.
Requirements
  • ArcGIS Desktop 10.1, 10.2  * Known issue with ArcGIS 10.2.2 and version 1.2 of Open Web Maps tool.
  • Windows Vista/7
  • Internet Connection
You could also try Arc2Earth.
Jay
Think Location
tanerkoka1
Can I use in ArcGIS Desktop 10.3
Thanks
JayantaPoddar
No. This add-in is not compatible with ArcGIS 10.3 for Desktop, as yet.
You could check if the update of Arc2Earth trial is compatible with v.10.3 or not.
Think Location
BrianFlood
fwiw, Arc2Earth is compatible with ArcGIS 10.3 and will soon be available in ArcGIS Pro as well
cheers
brian
