How can I load a private layer giving the the App login data ?
2190
06-13-2016 10:28 PM
Amalka_Chandrasiri
Im trying to load a private feature layer using app login. I have my App ID and a generated token and I'm trying to feed that data to a credential object and load the feature layer. But when the layer get loaded it still askes for log in infomation even though I have them attacehd with the feature layer.
How can I load a feature layer providng my app login info so that it will not pop the login info dialog ? Please help
Find below the code I tired.
function layerLoad()
  require(["esri/request", "esri/layers/FeatureLayer", "esri/Credential"],
  function(esriRequest, FeatureLayer, Credential) {
     var layers = [];
     var featureLayer;
     var layerOptions;
     var token = "L7yIuZW-h9ODkLRHOpnWpYlxHzHVIUdUgKQQKHqPLOVrNHMYi3clvlCTF6V5Xw64Xor-TUsUtrmfKXnQ5iomxO6_ltRRGFpq-UlO01C4XnIN6wSxjtHp15ciXeUIsEEA3cknZKsFKA1IrE_P28zmug..";
     var privateLayerUrl = "http://services.arcgis.com/u1pyDfVudZJk1pG6/arcgis/rest/services/Private_Layer/FeatureServer";
     var privateLayerWithToken = privateLayerUrl + "?token=" + token;
     var layersRequest = esriRequest({
       url: privateLayerWithToken,
       content: { f: "json" },
       //form:{ token: token },
       handleAs: "json",
       //callbackParamName: "callback"
  var credentials = new Credential({
  userId:"eR4g2n1Qv1U18Od4", // App ID
  token: token
  layersRequest.then(
  function(response) {
            layerOptions = {
    outFields: ["*"],
    mode: FeatureLayer.MODE_ONDEMAND,
    //credential:credentials,
    visible: true
            featureLayer = new FeatureLayer("http://services.arcgis.com/u1pyDfVudZJk1pG6/arcgis/rest/services/Private_Layer/FeatureServer/0", layerOptions);
  featureLayer.credential = credentials;
            layers.push(featureLayer);
  map.addLayers(response.layers);
  console.log("Success: ", response.layers);
  function(error) {
   console.log("Error: ", error.message);
Tags (1)
Amalka_Chandrasiri
Please note the credential object is commented in the above code example which is a mistake, When I try it was uncommented.
