Get length of roads in a polygon using Arcade
2316
11-19-2019 12:20 AM
KrishV
Dear All,
Is it possible, to get the Length of Roads in a polygon layer using Arcade. I tried something below:
var fs = FeatureSetByName($map, 'Roads')
//Clip(geometry, envelope)
var roadsLength = Clip(fs, $feature)
Length(roads, 'kilometers')‍‍‍‍‍
How can I achieve this.
Regards,
Krish
XanderBakker
Esri Esteemed Contributor
Hi krishnavsav ,
See below what you can do. This code is not optimized to enhance readability, however, depending the amount of lines you have in a polygon, this could result in a performance hit, since there will be multiple requests to the server.
// get the lines feature set:
var lines = FeatureSetByName($map,"Tubería Acero");
// select only the lines that intersect with the polygon
var relevantlines = Intersects($feature, lines);
// count the overlapping lines
var cnt = Count(relevantlines);
// set the initial total length to 0
var totlength = 0;
if (cnt > 0) {
    //  there are overlapping lines, loop through each line
    for (var line in relevantlines) {
        // intersect the line with the polygon
        var lineint = Intersection(line, $feature);
        // add the length to the total
        totlength += LengthGeodetic(lineint, 'm');
return totlength;
PaulDoherty2
Thank you for posting this @XanderBakker  this is exactly what we were looking for in our Urban Search and Rescue search segment planning tool. You rock!
