Geoprocessor issue with large dataset
1942
10-07-2015 06:48 AM
AzharIbrahim
I've been using the Geoprocessor Execute method to run tools in my Add-In. When using the Add-In on a large dataset, the application crashes when it hits Execute. There are no geoprocessing messages and I can't catch any exceptions, so am not sure what to do to fix the issue. The Add-In works fine on smaller datasets, and the tools that I am executing work normally in ArcMap on the dataset causing the error.
I'm releasing cursors after I'm finished with them. The dataset is not exceptionally large, so I'm not sure what to try next.
