Error handling service request: Could not initialize service 'Utilities/PrintingTools.GPServer'
3325
04-29-2018 10:19 PM
HaoHu
All the Geoprocess Service on my ArcGIS Server are not running properly. For example, when I click the PrintingTools under Utilities, I got the following error,
Error: Error handling service request : Could not initialize service 'Utilities/PrintingTools.GPServer'.
Code: 500
Then, I went to ArcGIS Server Manager and tried to restart the PrintingTools (Geoprocessing Service), I got the following error,
Service failed to start
Utilities.PrintingTools.GPServer:
RMMS-SERVER13.AD.UILLINOIS.EDU
Service containing process crashed for 'Utilities/PrintingTools.GPServer'.Please see if an error report was generated in 'C:\arcgisserver\logs\RMMS-SERVER13.AD.UILLINOIS.EDU\errorreports'. To send an error report to Esri, compose an e-mail to [email protected] and attach the error report file.
I further opened the error report and here is the summary,
Did anyone see the similar issue before? Please help!
TomWeisenberger
Having the same problem here.  It just started out of nowhere.  Dump file shows the same server OS Version, may be related to a Windows Update.
I opened a support case with Esri, will post any resolution.  Hao Hu did you get this resolved?
