Does the .prj file require the AUTHORITY tag for a CRS not recognised by ESRI or EPSG?
3596
11-03-2015 04:12 AM
StephenDowd
I am writing shapefile sets for CRSs that are not always in the EPSG database. It seems that ArcGIS does not accept the AUTHORITY tag unless it references a valid code e.g. AUTHORITY["EPSG", "2000"]. Does the PE require this tag or can it be omitted under these circumstances? If not then which strings should it contain?
Thank you
Paul
Tags (1)
MelitaKennedy
Esri Notable Contributor
It can be omitted. We don't use custom authority information right now anyway.
Melita
DanPatterson_Retired
Melita Kennedy​ flagging this one in case you miss it.
curtvprice
I suggest looking at examples at http://spatialreference.org
MelitaKennedy
Melita
StephenDowd
Thanks Melita
Paul
