Clipfilter from ImapClipOptions doesn't work
1179
10-14-2016 08:49 AM
S_I_T__srlServizi_di_Informazi
I have problem using the interface IMapClipOptions, about ClipFilter property.
I can successfully enable the clipping of a dataframe, but not excluding layers from the clipping.
Setting it manually, I can get programmatically the Layer the is in the ISet of the excluded layers, I can remove them, but I cannot set it.
I'm testing i in VBA, ArcGIS for Desktop 10.3 (Advanced).
This is the piece of code that I'm testing
Dim pDoc As IMxDocument
Dim pMap As IMap
Dim pMapClipOptions As IMapClipOptions
Dim pActiveView As IActiveView
Dim pGeometry As IGeometry
Dim pLayer As ILayer
Dim pLSet As ISet
Set pGeometry = fnvFClass_GetByName("Taglio_2K_Mask").GetFeature(173).ShapeCopy
Set pDoc = ThisDocument
Set pMap = pDoc.FocusMap
Set pMapClipOptions = pMap
Set pLayer = pMap.Layer(0)
pMapClipOptions.ClipType = esriMapClipShape
Set pLSet = New esriSystem.Set
pLSet.Add pLayer
pMapClipOptions.ClipFilter = pLSet
pMap.ClipGeometry = pGeometry
Set pActiveView = pMap
pActiveView.Refresh
The only custom code is the one used to get the geometry for the clipping.
Any idea about what could be the problem?
Thanks in advance
Francesco N. Vespucci
