Can someone Help setting up Koop server
2365
6
01-11-2018 08:13 AM
JeffPace
Can anyone help setting up a koop server? I have used node js before (barely) but it seems like the documentation is missing massive amounts of steps.
I cant even really get started.
Anyone done this before?
Tags (1)
JeffPace
EricShreve
I would like to know the process as well! I attempted to try it a couple months ago but was unsuccessful.
-Eric
JeffPace
jseppi
JeffPace
DanielFenton1
Hi Jeff, which providers are you trying to set up? Have you been through this document? Setup
JeffPace
I cyber stalked Alex Harris via linkedin and he got me up and running.  The instructions are painfully brief in places.  For example step two gives you some code, but it doesnt say "copy this code into a file called index.js, save it, and then run node index.js to start the koop server" for example... It requires or assumes alot of working knowledge of node, etc.
I got mine up and running and got a FeatureServer from an online service that returns points in geojson.  Right now my only struggle is getting the points to symbolize to a icon from a web url based automatically.
