Can I create an editable feature service in 10.2.2?
3565
04-01-2016 12:23 PM
JoseSanchez
Hello everyone,
I created a map service in ArcGIS Server 10.2.2 with feature access enabled. The feature points to a SDE Oracle instance and I can edit the layer in ArcMap because it is versioned.
When I try to open the Feature Layer with "Open in ArcGIS for desktop", it opens the feature in ArcMap and it displays the following error message "the workspace containing this data can not be edited"
I am using ArcSDE 10.0 and ArcGIS Server 10.2.2
Is there any limitation in 10.2.2 for editable feature services?
JoseSanchez
After checking this post  Creating an editable feature service
I am able to add the Feature Service to the map,then right click on the group layer, do you see an option to Create a Local Copy for editing, and edit in ArcMap.
The question now is how to edit in ArcGIS Online.
