allow geolocation
4841
05-04-2015 12:52 AM
sundussabbah
I'm developing app on a mobile and I want to obtain the current location of the device
I used this code:
require(["esri/map", "esri/geometry/webMercatorUtils", "esri/geometry/Point"],function(Map, webMercatorUtils, Point){
if (navigator.geolocation) {
navigator.geolocation.getCurrentPosition(zoomToLocation, locationError);
navigator.geolocation.watchPosition(showLocation, locationError);
function zoomToLocation(location) {
var pt = webMercatorUtils.geographicToWebMercator(new Point(location.coords.longitude, location.coords.latitude));
// map.centerAndZoom(pt, 16);
function showLocation(location) {
if (location.coords.accuracy <= 500) {
  go.alert(
'<=500');
else {
go.alert(
'>500');
function locationError(error) {
switch (error.code) {
case error.PERMISSION_DENIED:
  go.alert(
"Location not provided");
break;
case error.POSITION_UNAVAILABLE:
  go.alert(
"Current location not available");
break;
case error.TIMEOUT:
  go.alert(
"Timeout");
break;
default:
  go.alert(
"unknown error");
break;
but it returned this error:  error.PERMISSION_DENIED
which I think mean that geolocation is not enabled
How can I enable it and solve the problem???
ChrisSmith7
Honored Contributor
Sounds like you will need to enable location services on the mobile device.
Here are instructions for Android:
Enable Location Services - Maps for mobile Help
And iPhone:
how do i enable locations services, after origi... | Apple Support Communities
ChrisSmith7
Honored Contributor
And iPhone:
sundussabbah
thank you very much
I was mean enable it by programming
but I understood that the problem occurs because I run the app on simulator, but when I run it on real device it worked
thanks.
