Add a map to EsriMaps in MicroStrategy
10582
03-06-2015 06:11 AM
KatleenVer
Hi!
I am trying to visualize the revenue on a map, using longtitude and latitude.
This has worked when using the standard worldmap from EsriMaps, however I need a map of Belgium with all the provinces.
I already found a map that would suit what I need:
http://www.arcgis.com/home/webmap/viewer.html?url=http://services1.arcgis.com/XLY7M6F9oPzjvKmJ/ArcGI...
And I tried to import this by making a new EsriConfig.xml as I am using MicroStrategy 9.4 hotfix 8.
In the addition you can find the file I created in order to use this map.
Can anyine see what I did wrong?
Regards,
Katleen
ChakaClarke
Esri Alum
I you have the ESRI Maps for MicroStrategy v2.0 plugin there is a simple work flow for doing this
Esri Maps for MicroStrategy | Location Analytics
Add a location type—Esri Maps for MicroStrategy | Location Analytics
