400 Bad Request when Getting Token for client_credentials Request on Private Server
1215
09-26-2025 03:29 PM
RockyCherry
I have been using the ArcGis Online auth service with some web maps and now we're migrating to our own internal server.  We're using client_credentials, so a typical URL would look like this:
https://www.arcgis.com/sharing/rest/oauth2/token?client_id=<clientId>&client_secret=<client_secret>&grant_type=client_credentials
On our server, the portal URL is https://our.internal.url.com/portal/.  So, our auth URL should be (if I'm correct):
https://our.internal.url.com/portal/sharing/rest/oath2/token?client_id=<client_id>&client_secret=<cl....
However, when I hit that, I get 400 Bad Request with the message "Error: Invalid URL".  What am I doing wrong? 400 Bad Request means it's able to access the URL, so I don't think it's an access or routing issue... but no clue what else to check or try.
Any ideas?
HildermesJoséMedeirosFilho
https://developers.arcgis.com/documentation/security-and-authentication/reference/rest-authenticatio...
HildermesJosMedeirosFilho_0-1759839137269.pngHildermesJosMedeirosFilho_1-1759839159979.png
I would double check if you mispelled something in the code, if you did you get 200, but a page...in html
You can pass format json to get the proper error code.
If I`m not mistaken the api is jsonp compliant unless turned off
https://developers.arcgis.com/rest/enterprise-administration/server/handlersrestservicesdirectoryedi...
