why isn't the magnetic declination working?
1471
01-27-2020 03:57 PM
ChristoferSmith
Using ArcGis Pro, and the Magnetic North arrow in layout is no-longer working, it's the same as the grid north....and the dynamic text for the magnetic declination is also the same as grid north.
ShaneMiles
Hi Christofer Smith‌,
What part of the world are you trying to map and do you know what the magnetic declination should be for that area? This could rule out the chance of it falling on an Agonic line where the declination is zero. I notice with the Magnetic arrow you set the calibration. If you add in the topographic north arrow does it have the same issue with 0 Grid - Magnetic variance? Hopefully this helps answers your question.
Shane
ShaneMiles
Shane
