Failed to create Rule Engine: mil2525c
1188
01-09-2018 07:07 AM
MauroCastaldo
I'm developing an UWP solution using 100.2.0 .NET Runtime and I should display some military tactical graphics on a map.
I'm trying to use mil2525c.stylx with this code:
DictionarySymbolStyle symbolDictionary = await DictionarySymbolStyle.OpenAsync("mil2525c", installedLocation.Path + @"\Assets\mil2525c.stylx") as DictionarySymbolStyle;
Running application it shows this error:
File not found: Failed to create Rule Engine: mil2525c
I noticed that that method only accepts "mil2525c_b2" as specification type but it doesn't render any tactical graphics.
The only way I was able to make it render some tactical graphics is using
DictionarySymbolStyle symbolDictionary = await DictionarySymbolStyle.OpenAsync("mil2525c_b2", installedLocation.Path + @"\Assets\mil2525c_b2.stylx") as DictionarySymbolStyle;
Frankly I don't understand the relationship between specification type parameter and *.stylx file.
Is specification type related to military standard?
Is there a list of valid values for every *.stylx file (for example, I would like to know the correct specification type related to the "app6b.stylx")
Thanx in advance.
Mauro
KerryRobinson
Please see answers to this question in the Runtime SDK for .NET forum here: https://community.esri.com/message/740643-failed-to-create-rule-engine-mil2525c
