Output raster of Classify pixels using deep learning is blank
2345
06-24-2025 06:40 AM
Labels (3)
MelodyYu
Dear all,
When I tried to use the tool ' ClassifyPixelsUsingDeepLearning', I got the result raster in the contents list and the folder. But it's compeletely blank in the map workspace.
Could anyone can help?
DanPatterson
MVP Esteemed Contributor
I presume the map wasn't empty when you ran the tool, so right-click on the layer in the table of contents and select "zoom to layer".  It may be there but doesn't have a defined coordinate system so it is appearing out of the current bounds.
... sort of retired...
MelodyYu
Dear Dan,
Thanks for your advice. I tried zoom in it's still blank, and the coordinate system is the same as the map. But when I changed the symbology from ‘unique values’ to ‘stretch’, it showed up as black-and-white checkerboard. I guess it's because of my software environment...
ShivaniPathak
Hi Melody,
Can you please share some information:
  • Which ArcGIS Pro version are you using and how you created the deep learning environment.
  • Which model architecture have you trained i.e. UnetClassifier, DeepLab, etc.
  • Share screenshot of Classify Pixels Using Deep Learning tool parameters.
MelodyYu
Hi Shivani,
Here are the details:
Best,
Melody
ShivaniPathak
Hi @MelodyYu,
Thanks for sharing the information. I have few suggestion which I would like you to try:
1. With the output raster which you are not able to see and seems blank:
  • In the below screenshot we can't see "HR_Luchtfoto_2_80cm" raster in the map and seems blank raster:
  • But when I use explore and click on the map I can see the rasters class values:
  • By adding the raster in a new map we can see the raster in the map:
  • You can try this for your output raster.
2. Changing cell size in Classify Pixels Using Deep Learning tool:
3. By visual interpretation the raster which you shared doesn't seem like it's spatial resolution (cell size) is 10 cm so you can also try High Resolution Land Cover Classification - USA (https://www.arcgis.com/home/item.html?id=a10f46a8071a4318bcc085dae26d7ee4) which works for raster with cell size between 80cm - 1m.
