Data Pipeline for sending data
761
12-11-2025 08:00 AM
Labels (2)
ChrisBerryman
Curious on if there is a way to send data to databricks from arcgis using pipelines?  We have Databricks and will be moving to the Utility Network and are looking for ways to send data to databricks.  Can that be done with data pipelines?  OR is it best to just write a python notebook to handle it?
BethanyScott
Hi @ChrisBerryman ,
Thank you for reaching out.
No, Data Pipelines currently only supports reading data in from data sources such as Databricks, not writing data out. The only output data location supported by Data Pipelines is writing to hosted feature layers or tables stored in your content.
Please feel encouraged to contact Esri Technical Support to submit a formal enhancement request.
Thanks again,
Bethany
BruceHarold
Esri Frequent Contributor
@ChrisBerryman ArcGIS Data Interoperability extension for Pro 3.3 or higher can write to Databricks, the format is supported for read and write.  Support is a user install from FME Hub, which you do by simply adding a reader or writer to an ETL workspace.
