Connecting to open Overture maps foundation data
596
09-08-2025 03:41 AM
SimonNigh
Hi there
I want to connect to overture maps foundation data publicly  hosted on S3 /  Azure blob storage. The connection details here: Accessing the Data | Overture Maps Documentation suggest that credentials aren't needed to access the data. However when setting up the connection in Data Pipelines I'm asked for credentials by default. How do I set this up as data source for my pipeline - I am, not fussed if I use S3 or Azure for this, I just want to access the data as an input to an ETL process.
BethanyScott
Hi @SimonNigh , thank you for reaching out.
Data Pipelines does not currently support connecting to data sources using anonymous authentication methods.
We will take your feedback and use case into consideration for planning future releases.
Thanks again,
Bethany
