Can an Enterprise Data Pipeline call a Power Automate flow (to send an email)?
859
03-19-2026 07:00 AM
Bud
Legendary Contributor
Regarding ArcGIS Data Pipelines for ArcGIS Enterprise:
Can a pipeline be set up to call a Power Automate flow?
For example, a daily pipeline job to query if there are any construction projects in a EGDB FC where the  PROJECT_STATUS=FUTURE  and the DATE <= sysdate. If any records are found, then call a Power Automate flow to send a user an email. In other words, Scheduled emailed reports in ArcGIS Pro/ArcGIS Enterprise (centralized; server-based, no-code).
Use case explanation:  The construction project was entered correctly at the time the data was initially entered, but now it's out of date. This situation could not be avoided using editing constraints like an attribute rule, since the information was correct at the time it was entered. The only thing that has changed is: time has passed. We need to be notified by email about this issue so we can edit/update the data.
Related Pipelines Idea: Call Power Automate flow from an Enterprise Data Pipeline to send an email
Sarah_Hanson
Hi @Bud, thanks for your question!
Support for integrating ArcGIS Data Pipelines in ArcGIS Enterprise with Microsoft Power Automate is not possible today. This is only supported for ArcGIS Data Pipelines in ArcGIS Online currently.
To ensure your request is effectively captured, I'd suggest you submit your request to ArcGIS Connectors for Power Automate Ideas.
Thank you!
Sarah_Hanson
Thank you!
Bud
Thanks.
I submitted an ArcGIS for Power Automate idea, as you suggested: Integrate ArcGIS Data Pipelines in ArcGIS Enterprise with Microsoft Power Automate
Bud
@Sarah_Hanson Regarding ArcGIS Data Pipelines in ArcGIS Online and Power Automate:
Can an AGOL pipeline call a power automate flow (to send an email)? Or is only the reverse possible: use a power automate flow to run an AGOL pipeline?
Sarah_Hanson
Hi @Bud  —  Only the reverse: run a data pipeline in ArcGIS Online from Power Automate.
