Z Value snapping in ArcMap
723
12-08-2013 12:55 PM
TimothyElliott
I am after a way to snap Z values in ArcMap.
Essentially I have several thousand point features that need converting to different lines or polygons, I can snap the xy easily enough but was after a z value snapping as well. The editing in ArcScene and globe is problematic at best.
Yes I could use the feature to line / poly etc but that would also take longer to sort out the selection and definition queries etc to get it all right.
I was thinking that an update vertex from point process or script would be ideal.
