XML workspace schema export failed - application in licensed to ceate or modify ...
1103
01-10-2013 02:47 PM
PaulHiggins
Trying to export a XML workspace document for a SDE database (SQLServer based) in ArcCatalog If I try and do the whole database.  I get the following error:  XML export failed The applicaton is not licensed to create or modify schema for this type of data.  If I go down the tree to the individual feature data sets and do the export all of them work but one with the same error message.  Not sure why this is happening I am fully licensed and this is an export....there is nothing that is changing the the geodatabase schema...??
