Unable to get domain values from date domain coded values in ESRI 9.3.1
1077
11-30-2012 12:29 AM
manojsingh
if We create a date field and apply a domain which have coded value of this field. after adding some record and if we refresh the connection (disconnect and connect again) the code value of date field domain is getting changed with some numeric value, even if we get the code value via arcobject the it's returning the same numeric value.
I used ICodedValueDomain interface to fetch the date domain field value but unable to get the actual date which we stored.
Please let us know the solution
[ATTACH=CONFIG]19626[/ATTACH]
manojsingh
I have faced the same issue, but could not get the resolution and i have also not heard from ESRI regarding this. As per one of my friend this has been fixed in newer release of ArcGIS 10.1
:confused:
