XML file import to gdb
6018
01-05-2011 07:31 AM
MatthewArsenault
Hi, I have an XML file (and an XSD file, schema for it) and I am told I should be able to import and turn it into a gdb, but I can not for the life of me figure out how.  Anyone have any suggestions?
Thanks.
DerekLaw
Esri Esteemed Contributor
Hi there,
Please review this help topic:
Hope this helps,
MatthewArsenault
Hi Derek,
Thanks for the reply.  I already tried that, having found the XML import (as you highlighted) in the online help section.  It did not work.
In theory, so I am told, the XML (which came from an outside program, exported that is) is easily brought into ArcGIS. I have seen the points (from another file) displayed in ArcScene.
I was given 2 files, one is XML and one is *.xsd, I have attached them in a zip file.  Any advice?
