why when i convert ratser to ascii the values chanes. for eaxmple my ratser low value is.0113 and high value is 0.15 but when i convert it to ascii both hign and low value showed .0113. Why this is happening? How can I get similar value after conversion.
4934
06-25-2016 05:19 AM
AMNAALRUHEILI1
Plz help me to figure out why when I am converting my 32 float bit raster to ascii my values changed? Why does this happen?
DanPatterson_Retired
try scaling the raster up by a factor of 10 or 100 first, just remember what you scaled by and see if it goes to ascii then
AMNAALRUHEILI1
Do you think the problem is because the raster is float and not integer?
Did you marked it assumed answered? I thought the scaling and conversion to integer or just the scaling would have solved it.  If not, you will need to provide some more information
AMNAALRUHEILI1
I am still working on it. I am still having hard time. My raster is at 1m cell size and need to be at 32bit float.
why the need to get the raster to ascii?
why did you bring in the ascii back into arcmap?
a description of what you are doing would go a long way to identifying your process
