White lines seen after mosaic
1448
10-05-2012 01:52 AM
bernardfoong
I had converted several polygons to shapefile and merged all the shapefiles using the "mosaic to new raster" function. After merging, there were white lines at the edge of each region. I thought that the "mosaic to new raster" function would smoothen the edge?
How do I remove these lines so that the edges are uniform? I have attached the image here.
As i am still new to this software, I hope that someone can guide me along here. Many many thanks in advance.
Bernard
RyanClancy
Bernard,
You're talking about polygons (vector) and shapefiles (vector) but then you used the mosaic to new raster tool. Unless you actually want raster data, I think you should use the Merge tool.
http://resources.arcgis.com/en/help/main/10.1/index.html#//001700000055000000
Ryan
bernardfoong
Hi Ryan,
Thank you for your response.
Actually I intend to get the censor data of several county. For each county, I created a separate dbf file and combine the census data to shapefile for the county obtained from TIGER.
Now that all the polygons has the required census data, I want to merge all of them so that a single output will show the census information of different county.
When I merged using the polygon, my census data is not presented. So i decided to convert to a raster then merge the raster together. But as you can see, theres white lines at some portion.
What should be my next course of action? I want to remove those white lines.
THanks,
Bernard
