Where can I download address locator styles? I'd like to try a few different address locator styles but cannot find them.
Thank you.
Solved! Go to Solution.
Hi Robert Scheitlin, GISP what locator style did you use to create a parcel locator that returns parcel polygons rather than points? I have parcel data that I am creating a locator over and each locator style I try uses the parcel centroid as the return 'flash'. I want the parcel shape to be the locator output.
Thanks for your help.
- Jake
Hello Robert, just a follow up question if you or any person has a solution or suggestion. I am using US address - dual range and my reference data has a field for municipality and my goal is to return the municipality of each record geocoded. Using this style there is no option for 'additional field'. Is there a way to manipulate the properties of the US address - dual range to include the municipality field in the output table?
Simon.
I just discovered there is an option to include an additional field for both the right side of the street and the left side of the street. I included the Municipality field on both the right side and left side and now I have the multiplicity data added to output geocoded table.
