When I select records in a shapefile problem
5144
07-29-2014 07:41 AM
ThomasCullen
When I select records in a shapefile to create a new layer, the select fails after a brief period of time. All the records from the original file appear in the new layer not just the ones I selected. I use arcmap 10. What am I doing wrong?
TimothyHales
Esri Notable Contributor
How are you creating a new layer? Are you using the option to "Create Layer From Selected Features", or are you Exporting the data to create a new shapefile?
ThomasCullen
I am trying to create a new layer. thanks.
ThomasCullen
Create layer from selected features.
TimothyHales
DanPatterson_Retired
Why try the suggestions in the Help file
