when I resample the image to the coarse resolution I get many nan pixels and the new image does not cover the whole areas How to solve this?
2976
5
10-23-2014 07:55 AM
hanaklein
larryzhang
How did you do that? What is the Gp tool you used for resampling?
Genreally, you can use  two ways in Arc to do:
1. Export via setup coarse pixel;
2. Gp 'resample'
hanaklein
I used Arcgis. In data management tools I used resample option and selected the cubic method
larryzhang
Your GP used is right.
However, 'out_raster' format  in your mission was properly in TIFF.
Pls try *.IMG as out_raster format...
Refer to ArcGIS Help (10.2, 10.2.1, and 10.2.2)
DanPatterson_Retired
If using tools in Arctoolbox, which Resample method are you using?
hanaklein
Cubic method
