when add FIT file in Arcscene, go down the resolution so much...??
1649
08-12-2013 12:11 AM
tae_junjung
in Arcscene,
i added FIT file(high quality aerial photograph),
but it's resolution too lower than in arcview....
i operated some properties.. but it go down more and more
someone help me!
JeffreySwain
I am not sure what a FIT file is, but in ArcScene you can control the quality of the raster as described in this blog.  Remember that ArcScene loads everything into memory, so that larger rasters can cause other display and performance issues if the quality is raised. I recommend testing out different sizes and qualities to see what works best for you.
tae_junjung
sorry, not FIT..... it is TIF ^^;;
then,,, can you give me another advice??
JeffreySwain
The process is still the same, follow the blog and adjust the look of the rasters in ArcScene.  The procedure described in the blog are raster format independent.
tae_junjung
oh~ thanks! i solve the problem.^^
but arcscene seems very heavy program?
if i notch up "Quality enhancement for raster images" bar, so hardly working...
ummmm...
