What unit does an Attachment table's DATA_SIZE field use?
4769
06-02-2015 09:16 AM
847396730
I am troubleshooting an issue I suspect is related to database size.  After enabling Attachments on a feature class, there is a resultant table called FeatureClassName_attach, and that table contains a field called DATA_SIZE.  What unit is this field in?  No matter what unit I guess, the result seems crazy, and I can't find a definitive answer in the documentation.
Thanks!
DT10.2.2, SQL Server 2008R2, SDE gdb 10 & 10.2.2
847396730
I'm going to say it's bytes.  Although I confirmed with IT that the database settings are indeed generous and could support absurdly large records, logic suggests these must be bytes.
I would welcome any recommendations on how to confirm.
Thanks!
SepheFox
Are there values in the fields?
bsneller_esrinederland
I attached a JPG to a feature and compared the value and the size on disk: indeed DATA_SIZE is in Bytes
