what is problem of my code?
1324
10-13-2011 06:29 PM
hexuezhou
int CreateFileGDB(std::wstring filegdbPath,std::wstring filegdbName,Geodatabase &newFGDB)
 fgdbError hr;
 wstring errorText;
 Geodatabase geodatabase;
 wstring fgdb;
 fgdb.empty();
 fgdb.append(filegdbPath);
 fgdb.append(L"/");
 fgdb.append(filegdbName);
 //Try to delete exist the same filegdb
 hr = DeleteGeodatabase(fgdb);
 if (hr == S_OK)
  wcout << "Find the GDB exist,then the origin geodatabase has been deleted" << endl;
 else if (hr == -2147024893)
  wcout << "The geodatabase does not exist, no need to delete" << endl;
 else
  wcout << "An error occurred while deleting the geodatabase." << endl;
  ErrorInfo::GetErrorDescription(hr, errorText);
  wcout << errorText << "(" << hr << ")." << endl;
  return -1;
 // Create a new geodatabase in the parameter Path.
 if ((hr = CreateGeodatabase(fgdb, geodatabase)) != S_OK)
  wcout << "An error occurred while creating the geodatabase." << endl;
  return -1;
 wcout << "The geodatabase has been created." << endl;
 newFGDB = geodatabase;
 return 0;
In this code the error exist in line "newFGDB = geodatabase".
the error is : IntelliSense: "FileGDBAPI::Geodatabase &FileGDBAPI::Geodatabase::operator=(const FileGDBAPI::Geodatabase &)" (code the line: 283,belong file: "F:\SoftWare\ArcGIS\FileGDB_API_VS2010_1_0Final\samples\..\include\Geodatabase.h")
thanks very much!
VinceAngelo
Esri Esteemed Contributor
The 1.1 version of the FileGDB API was released back in August;  you probably want to try
using that before visiting the File Geodatabase API forum to ask further questions.
- V
hexuezhou
Okay!
Thanks all the same!
hexuezhou
#include <string>
#include <fstream>
#include <iostream>
#include <FileGDBAPI.h>
#include "CSchemas.h"
using namespace std;
using namespace FileGDBAPI;
int main()
 int iexecuteStatus;
 Geodatabase newFGDB;
 //1.Create File Geodatabase(path,name,gdb)
 iexecuteStatus =CreateFileGDB(L"C:/Temp",L"test1.gdb",newFGDB);
 if(iexecuteStatus!=0)
  wcout<<L"create file geodatabase error!"<<endl;
  return -1;
 return 0;
//Create File Geodatabase for Format Convertion
//Author: Hexz
//CreateTime:2011-10-13
//Version:1.0
//Revision:No
int CreateFileGDB(std::wstring filegdbPath,std::wstring filegdbName,Geodatabase& pnewFGDB)
 fgdbError hr;
 wstring errorText;
 wstring fgdb;
 fgdb.empty();
 fgdb.append(L"/");
 if (hr == S_OK)
 else
  return -1;
  return -1;
 return 0;
I have used version1.1 ,but vs2010 show the same error!
as code paste in the thread.
could help  my code error?  Thanks
VinceAngelo
Please ask in the appropriate Forum (after reviewing other similar posts).
- V
