Way to find version of SDE
20196
18
04-30-2010 09:14 AM
FarooqMunir
Just wanted to ask, is there an easy way to find out the version of SDE running either from ArcCatalog or just by logging onto Oracle ?
FM
SachinChand
Vince, thanks for the quick response.  What about an instance where all versions are 10.  ArcGIS Desktop is then updated to v10.1.  From desktop, the sde geodatabase is upgraded to v10.1 which would still leave ArcSDE at v10.
VinceAngelo
Esri Esteemed Contributor
No, after you upgrade the geodatabase, the SDE is at that level.  If you have an application
service, and you fail to delete and recreate it, that's an error.
- V
SachinChand
Ok, so with the scenario I presented, an sde service would need to be recreated, understood.  Direct connect should work fine though (after upgrading the geodatabase to v10.1 using desktopv10.1), right.
VinceAngelo
Correct.  Direct Connect is its own ArcSDE server.
- V
SachinChand
Thanks for the clarifications!
VinceAngelo
Please start new questions in a new thread.
Views are just views; there's nothing release-specific about a view.  Any necessary changes would
either happen to the underlying ST_GEOMETRY object, or to the base table's triggers.
- V
NorlizaAbdul_Rahman
sqlplus sde/password;
select all from sde.version;
Bud
Legendary Contributor
I was able to use that query from a user/schema/owner other than SDE (a ROADS user):
--Oracle 18c
select * from sde.version;
It produced the correct information.
arahman_mdmajid
This worked for me. Thanks
Abdur Rahman
GIS Developer
