Warning Message using shp2SDE
1668
09-21-2010 10:17 AM
RachelLi
I was loading data to ArcSDE 10 workgroup database  use shp2SDE command. The data can be loaded but got the following error message,
WARNING: Unable to load code page translation table ...\Program Files\ArcGIS\Arc
SDE\sqlexe\\locale\codepage\125212.txt.
I noticed there are two back slashes after sqlexe. How can I get rid of one?
Thanks for your help,
Rachel Li
VinceAngelo
Esri Esteemed Contributor
Does the SDEHOME variable have a trailing slash? The fopen() function ignores duplicate
intermediate slashes, so this isn't likely the problem.
'shp2sde' isn't supported with Workgroup ArcSDE, but I doubt that's the issue either.
"125212" isn't a valid codepage ("1252" is) which I expect *is* the issue. Have you
explicitly set a variable for codepage encoding? Do any of your environment variables
contain "125212"?
This messge is a warning -- do you have codepaged strings in the source shapefile?
If not, then you can probably ignore this message.
- V
RachelLi
Thanks for your answer, Vince.
Rachel
