Using ST_length or ST_Y operator/function with in Oracle trigger
1344
03-29-2012 10:50 AM
YogeshShah
I could use following statement without any problems(Using SQL navigator)
select st_x(st_startpoint(s.shape)),st_Y(st_startpoint(s.shape)),st_X(st_endpoint(s.shape)),st_Y(st_endpoint(s.shape)),st_length(s.shape) from san_pipe s
I am trying to create an update trigger on san_pipe to get a length and coordinates and populate in feature class columns as under
:new.length_calc := st_length(:new.shape)
I am not able to compile the trigger and receive invalid use of operator error.
Are they not allowed to be used in trigger? Am I missing anyting? I also tried using sde.st_length
YogeshShah
It works now!
Used select st_length(:new.shape) into vlength from dual;
:new.length_calc := vlength;
Have fun!
VinceAngelo
Esri Esteemed Contributor
You should prefix operators for ArcSDE ST types and functions with "SDE." since
Oracle has reserved the synonyms for the SDO_GEOMETRY types.
- V
