Using SDEView to Create Dynamic Feature Class via Geocoding
1384
08-04-2010 10:52 AM
BryanDickerson
I have a question as to whether this is possible.  I have a table (A) in one Oracle database (1) that is non-geospatial data (no geodatabase) but contains street addresses.  This table is constantly being updated with new records.
I have a geodatabase in another Oracle database (2) running ArcSDE 9.3 SP1.
I want to create an SDE view (sdetable -o create_view) to table A resulting in sdeview B which is then geocoded against my address locators within an ArcMap document and used to create a dynamic feature class in the geodatabase (Oracle database 2).  In theory as new records are added to table A, they should appear in view B and then be dynamically geocoded and display on my map (assuming a valid street address).
I can create the dblink between the 2 databases just fine and, using standard SQL tools, query records from table A.  I can successfully create and register the sdeview using the sde command line tools.  I can successfully geocode to a dynamic feature class the records from view B.  However, it doesn't appear to be acting "dynamic".  I add a new record in table A in database 1, it appears in the sdeview in database 2 but, even though it is a valid and "geocodable" address it does not appear in my point dynamic feature class.
Suggestions or thoughts?
CarlAlexander
Did you ever find a solution to this problem?
JakeSkinner
Esri Esteemed Contributor
Geocoding results are not dynamic since the output is a feature class.  The only type of outputs that are dynamic in this matter are event layers.  You will need to re-geocode the addresses after the updates have been applied and overwrite the feature class.  I would recommend running a script to do this at a given time(s) during the day.
CarlAlexander
There is the option to do a dynamic geocode in SDE.  This works great when you update the table in ArcMap.  But updating tables in ArcMap is not part of our workflow.
ToddSmith
Bryan or Carl, did you ever find a solution to this problem?  I am trying to do something similar in SQL Server.
Todd
