Using non spatial view in sde
789
03-01-2011 03:45 PM
mohd_syafidabdullah
Hi Guru..
I have a scenario like this.I have sde and non spatial attributes in different database.
How can i use the oracle attributes in sde environment.
I able to create view in sde from non spatial database but it can't be used in sde..
Please guide..thanks.
VinceAngelo
Esri Esteemed Contributor
Views across DATABASE LINKs are possbile, but usually perform poorly if not
carefully tuned.
You cannot use the ArcSDE API to create a database link view, but you can create
a dummy table with the same columns (and same types), create_view to that, then
edit the view in SQL Developer, etc... so that it crosses databases.
- V
