Using Data Interoperability Extension with Oracle Spatial 10g
1200
07-27-2011 10:59 AM
PaulPostiglione
I'm new to the Data Interop extension.  We use GeoMedia Pro and are looking to access our Oracle tables in ArcGIS 10.  We do not have ArcGIS Server/SDE.  When I create my connection (using the Oracle Spatial Object Format) and load data into ArcMap, it does not zoom to the layer.  If I add a shapefile in the same location and zoom to it, I can see the data from Oracle.  Do the max/min extents not carry over or am I missing something in my Geometry Data?  Also, does anyone have any tips or how to's for using Oracle Spatial with the Data Interop extension?
Paul
DavidBrett
I'm trying something similar with an Intergraph G/Technology formatted Oracle Database.  In my efforts to connect, I was lead to this site:
http://fmepedia.safe.com/articles/Samples_and_Demos/Oracle-Spatial-Object#heading_toc_j_2
Specifically:
--Spatial Views
--ESRI Data Interoperability Extension (FME)
You may need to create a metadata entry for the feature and then an index.
...just a thought.
