User privileges
1607
11-21-2011 09:33 PM
AysberqTundra
Hello everyone!
I have a little problem.
I'm using ArcSDE 10 for Oracle  11g R2. I want that, the user could edit the geodatabase, but could not copy.
Whitch privileges I must give the user. (Create session, ....) ?
Thankes.
AysberqTundra
I have create a new user (USER1) and I have give all permissions for this user.
But USER1 can not edit any layer. When USER1 clicks Start Editing button gives following error.
Error: No editable layers.
I attached a screenshoot too.
But when I connect with SDE user I can edit the layers.
What I must do?
Thankes!
JakeSkinner
Esri Esteemed Contributor
When you granted privileges to USER1, did you use the 'Privileges' geoprocessing tool in ArcToolbox?
RobertHu
Did you register the layer as versioned? Or did you choose the non-versioned editing option?
AysberqTundra
I gave permissions for USER1 using the 'Privileges' geoprocessing tool in ArcToolbox and it worked.
My problem solved.
Thankes.
