US Address - Street Name - Intersections Connectors - Empty
6210
12
09-14-2011 11:16 AM
MichaelDesroches
Hi there,
Not sure if this is a bug, or if it is built in.
After creating a "US Address - Street Name" Address Locator, if I right click on the properties and try to add variables such as "@ / and &" they disappear after clicking OK.
Another Address Locator was built using the same information and the Intersection Connectors field is populated.
Any thoughts?
JoeBorgione
Glad you got it figured out; good catch Bruce!
Something I always like to mention when working with street data is the fact that some streets don't actually intersect: think about freeway overpasses.  Within the context of this particular discussion it's not a big deal.
But next week when the boss says "Kevin, since you did such a great job geocoding, I'd like you to do some vehicle routing with network analyst..."  is when building the killer street feature class comes into play.
BruceHarold
Esri Frequent Contributor
Hello
The US Street Name style does not support intersection geocodes.
Regards
Kevin_FernandoEscalera_Robles
thanks for the info, even though it is discouraging
