Upgrade to 10.1 error Cannot upgrade a user schema geodatabase
16019
20
08-29-2012 07:18 AM
by Anonymous User
Not applicable
Original User: nsridb
We are trying to upgrade a version 10.0 64 bit arcsde to a 10.1 64bit version (on Red Hat 5 64bit, Oracle 11 64bit).
We are getting the error message:
when the master schema geodatabase is at a previous release.
The master schema geodatabase must be upgraded first.
Unfortunately we don't have any user schema geodatabases as far as I can tell so can anyone tell me what the problem is.
I've checked the geodatabases using sdemon -o info -I instance and only the SDE master geodatabase appears.
Any help?
KenBohannon
I was able to get the Upgrade Geodatabase tool  to work by creating a new database connection using only the Oracle TNS name in the Instance text box, click OK, name the db connection and exit ArcCatalog.  Once I re-open ArcCatalog/ArcToolbox and attempt to upgrade, it runs successfully.  (SDE 10.2.1 to 10.3.1)
