Unregister as Versioned Throwing Schema Lock Error
1247
10-01-2024 06:19 AM
JoshBillings
Hey all,
I have a script that I have used several times in the past to unregister feature classes as versioned. I have had no issues with this in the past.
When I try to run the script now, I am getting a this error message:
"ERROR 000464: Cannot get exclusive schema lock. Either being edited or in use by another application or service."
The very first thing I do in the script is disconnect all users using this arcpy function
arcpy.DisconnectUser(sde_conn, "ALL")
I also double check to see if there is some user that may still be connected, but I am not seeing any through geodatabase administration in ArcGIS Pro nor is the DBA seeing anything on his side.
Is there something that I could be missing that could be hanging this up?
Thanks! - Josh
JoshBillings
This was a simple mistake on my end. I had the wrong database instance in my SDE connection file. This differed from the database instance that disconnected all users. This is why I was receiving the schema lock error.
JoshBillings
