Unpacking map packages offline
4091
03-13-2015 07:24 AM
michellewatson
I have created a map package that I need to unpack when offline (i.e. via a borrowed Arc licence).
While I can unpack while online i.e. I'm packing data from a shared server, when I go to unpack I encounter this error:
"Opening the selected ArcMap Document failed, An unexpected error occurred while loading the map document. The last successfully loaded component was.........The specified file does not contain a valid ArcMap document".
I can't figure this out. Is it to do with storing pathways as relative or absolute?
Any help would be appreciated and many thanks.
Mich.
