Undo "Add Point"
840
02-11-2013 12:22 PM
BenjaminBigelow
How do you delete points that were added using a locator or the Find-> Locations input?  I added several points to the map with the context menu in the Find pop-up, but I don't know how to delete them.
TarunJaiswal
Greetings!
If I understand you correctly these points are like graphics. You should be able to select them using Select Elements button (Black Arrow) on Tool toolbar and then press delete.
Hope this helps.
Thank you.
